Which HDMI where
True Blue
185
Hello all, currently have the following set up
Blu Ray to Receiver = Chord HDMI Active
Receiver to TV = QED Performance P
V+ to TV = Chord Supershield and chord Optichord to reciever for sound
PS3 to receiver = standard HDMI
Am about to get another Chord HDMI active now the question is where to place it?
Please I only want advice on cable placement in my system, if you do not believe cables make a difference then please do not comment.
Thanks all
Maybe use the new Chord to replace the QED from the receiver to TV? That way the chain from what I assume is your most important source will be using identical cabling. Then you can use the QED for the PS3 and scrap the bog standard HDMI.
