Hi all
This will be a familiar scenario to many of you, I’m sure: the latest album by your favourite group hits the shops and you’re keen to get your mitts on it. But which format do you buy it in? The CD version? The LP?? A download??? Of course, most of the time it’s potluck because you don’t have the luxury of being able to evaluate each version before you buy. After a fairly lengthy period of buying vinyl almost exclusively, with a number great purchases and a few too many clunkers, I came to my senses and decided that a more rational and methodical approach to music buying was needed if I’m to get the best out my system and music collection. So, when I’m thinking about buying an album I tend to use the following criteria:
Bogester
- Cost: how much are the different versions? Are they charging an arm and a leg for the vinyl? For example, recently I wanted to buy LCD Soundsystem’s farewell live album “The Long Goodbye”, but at $130 I felt it was just a little too expense for me at that time, so instead I plumped for the hi-res download at $33. If the price differential is hard to justify then I’ll tend to go for the cheaper version (CD or, rarely, MP3/M4A).
- Mastering: I usually try and found out who was responsible for mastering the album in its various formats. If the mastering engineer has a good reputation for, say, vinyl, then this might persuade me to buy the vinyl version. For example, the past two Mogwai albums I bought (“Les Revenants” and “Rave Tapes”) were mastered by Frank Arkwright, who has a very solid reputation with vinyl, so I bought them both on vinyl and wasn’t disappointed. If ,however, the mastering was done by someone I’m not familiar with or can’t find much info on, then I’m inclined to buy the CD if it’s significantly cheaper than the vinyl.
- Dynamic range: this is not the be-all and end-all of decent sound quality (I have some rather dynamically compressed CDs that sound somewhat better than their more dynamic vinyl counterparts), but it’s certainly a consideration. Like some here, I consult http://dr.loudness-war.info to see if there’s any DR info for the album I want to buy. If the DR of the vinyl version is significantly greater (more than a couple of dB) than other versions’, this might sway me to buy the vinyl version, but not necessarily, it will depend on the other factors.
- Genre: if it’s classical I’m after then it’s digital all the way! For other genres, the other factors are likely to be more important to me.
- Extras: does one version come with a load of extras not available with other versions? Do I even care about those extras? (Often the answer to that is a resounding “no!”. Demo versions of songs, anyone? I rarely find that I want to listen to those more than once.). And does the vinyl come with a free download? If not then that’s a definite black mark against it, especially if the vinyl is fairly pricey to begin with and has no particular pedigree.
- Customer/peer reviews: this is arguably the most important and useful criterion of all to me. I attach a lot of credence to what other listeners say about the quality of releases. I tend to do internet searches of the sort “<insert album name> sound quality vinyl/CD”, or peruse the forum pages of various websites, including WHF’s very own, Steve Hoffman, and so on. I’ve bought a number of albums in one format or other based upon opinions expressed in these very pages, for which I’m very grateful.
- Gut feeling: sometimes, despite all the research I’m none the wiser, so I’ll just go with my instinct! Sometimes I’m right, and sometimes…
Bogester
