Which 32 Inch??
Hi guys, thinking about getting a 32 inch tv, but confused as to which one. My budget is around £350 and have seen the Samsung LE32C530. Cant find any reviews at all for that tv..Will you guys at WHSV be reviewing this TV or will it be in your magazine at some point?
a friend of mine bought a 1080p 32in samsung last year , think it was the b530 , very nice little tv , great value too , around e450 i think , this years models should also be good , is it 1080p ? if so at the price it looks a good deal to me ...
Yeh its a full 1080p tv but with only 50hz, will i notice a difference when comparing to 100hz tv's?
http://www.amazon.co.uk/Samsung-LE32C530-32-inch-Widescreen-1080p/dp/B003EEM1M4/ref=sr_1_1?ie=UTF8&s=electronics&qid=1279904391&sr=8-1
maybe , its hard to say , but at that size you probably wont , samsungs are quite good without the 100hz ..
Hi - just read this and thought I might be able to help.
I too was considering the Samsung, but I need a TV to sound very good too, so would highly recommend the Philips PFL5405H (under £400), here's a place that has them very cheaply:
http://www.blaelectronics.co.uk/philips-32pfl5405h12-lcd-television-717-p.asp
They're very good TVs, 100Hz etc and excellent sound. Also check out 32" Sharp TVs, very good blacks/sound.
Hey thanks for that, the phillips looks a nice TV, but have you purchased anythin from BLA Electronics? What are they like? Also one thing that favours the Samsung is that it plays MKV files straight from a USB drive. Tried to find that on the Phillips but cant find any info on it.
