Clarkey_71
It was several years ago and was called M.C.D 102 MK 3
I can't recall. It was part metal, part carbon fibre. Fine across highs and mids, but the bass on (for example) One Love was awful.
Don't know about volume, but the VdH speaker cable I had tried to turn all bass notes into the same one, at least on certain tracks.
Looking at what's on eBay, that was the one. Didn't gel with MA GR20s for whatever reason.VD's CS122
I was asking about the VdH because the internal wiring of my Dynaudio speakers is VdH CS-12 hf. The CS-122 is the twin version of that same wire. So i thought it was logical for me to have the same speaker cable as they are internally.I liked VD's CS122. It was the the facto cable my local dealer used in most of their systems which included sensible and not so sensible ones.
They carried others incl Chord.
I did not have any issues with the VdH.
I think they did a similar thing with the Zen Blue, although that was more the connection sometimes being les than robust. The software update fixed that. Might be the same with the Stream?ifi zen stream. They released it to soon propably. It just would not connect to the wifi. Even with the ethernet cable "computer says no".
A bad batch i think. Didn't have the chance to do an update as it would not connect to the internet in the first place. I could get into the menu of the device and connected a usb stick with music on and it didn't read most of the files also.I think they did a similar thing with the Zen Blue, although that was more the connection sometimes being les than robust. The software update fixed that. Might be the same with the Stream?
I dont hear mine at all when I need tooMy wife? Sometimes I hear her in both ears but sometimes only one.
Some nice honesty there.Expensive cables by far.
Yes, there is a good reason why RS had them on clearance for £700!Seriously?
So what did they do with the mark ii that they are so universally liked while the original was so universally hated?Yes, there is a good reason why RS had them on clearance for £700!
