Whats the tv pic set up disc called ?
LOST
56
I remember there is a disc for setting up your tv pic to get the best out of it but whats it called as i cant remember ?
DVE Blu Ray disc or DVD disc (adjust red, green and blue colours). THX (adjusts blue only) does not come close.
I seem to remember that if you have a dvd disc which has the THX logo on the cover then go into the dvd films menu select the audio or THX option and you can use that its the same as doing it from the proper disk i think . I seem to remember using Star Wars to setup a TV for a friend and its saves you buying the proper disk so check you film collection!!!
I call mine "Eric", can't quite remember why.
Made by the good people at Monster Cable.
After running through that to get the basics, I use a Spyder 3 Pro device.
Doesn't get more accurate than that.
