What TV
I thought i would buy the mag to find out which TV to go for now i am more confused than ever. Help please.
I have a 100hz 32" Toshiba which has served me well but now wish to go a bit larger say 36-42". I have a budget of £1500 , watch movies and use an x box now and again. Sound is no problem as i have a decent hifi surround set up. I want to use HD asap via sky. Any ideas please, Thanks Dave
With that budget you have plenty of choice but most will suggest the Panasonic th42pz70 or Pioneer pdp-428xd.Check around for best prices.
Thanks for the advice , I think i`ll pop into my local dealer and see if I can tell the difference. If not I guess the cheaper option is the way to go. Thanks again. Dave
