What should I change
camcroft
1,024
669
20,070
Hi.I am new on here today .I have had my present system for a few years now.I hava a Sony TA-FE570 amp and Sony CDP-XE570 cd player and a pair of Mission 701 speakers.I would like some advice on what would be my best way to upgrade the system without having to change all the components.They were all 5 star rated (Whathifi ) in their day but times have changed and I have been out of touch for a few years so I would appreciate any advice.I recieved some Mordaunt short 902i`s yesterday and hooked them up to the system on stands and it shows how different an amp can sound, They are good little speakers but a bit on the small side and wern`t at the right listening level so there would be too much expence in buying taller stands.I would like some speakers about the same height as the 701`s even a good pair of second hand ones. Budget for speakers £ 100-£200.even if they are a few years old but would be compatable with my system or please let me know if I would be better changing something else. Thanks in anticipation.
Sorry.Music tastes,Rock.Blues.Easy listening.
Source. mostly cd,Streaming from ipod with Bluetooth device.
Interconnects.Qed.speaker cables Qed silver anniversary
Hi
This is tricky one as all your components seem to be competent. Although I've not heard the Missions, there are a few on here who rate the Mission 751s.
From your current set-up I've only heard the amp and I would suggest the CDP and speakers could be the weakest link here. Other than Missions, try listening to Wharfedale Diamonds 9.1 or 10.1 or perhaps B&W 685s.
