WHAT SETTINGS ARE BEST FOR PS3 FOR 5.1 SOUND!
Hi, want to check if my settings are correct for the ps3 to run 5.1 through my amp (Yamaha RX-
V667) Im using HDMI connection. Ive a fat ps3 60gb! Cheers guys!
I disagree with dirtys advice
Your amp should do a better job of decoding DTS and DOLBY DIGITAL so have it bitstreaming for those and PCM for HD material
for best compatibility u set the sound to be LPCM over hdmi.
aliEnRIK:
I agree with aliEnRIK but you will have to keep on swapping and changing the settings, this is what I did and it got on my nerves you put a film on then find out its on the wrong setting and have to stop the film and change it. In the end I bought a Sony BDP 370 so I could bit stream everything.
