What is the most secure, comfy and economical inear phones?
CaptainKirk
26
I want to get some in ear type of phones and I would like to know which are the best ones for just going on a walk outdoors.
I've had a pair of Senheiser PX100s for about 5 or 6 years now and they still give me great service and outstanding sound. Only had to replace the ear pads once last in all that time. But when I wear these outdoors, people stare or laugh at me so now I want something more discreet. Not that I care but it's a bit annoying (perhaps they think I' trying to be hip or something).
Having said that, I want phones that are secure (after all no point in phones that keep falling out), comfortable (that's the reason I bought the Senheisers in the first place) and sound that is good enough so it can be heard clearly and intelligibly despite traffic (I mostly listen to audiobooks). I heard air cushion/marshmallow ones are good but you can advise me on that.
Now I don't want to spend much - I' m only listening to a cheap RedMango MP3 player - so if you can recommend to begin with something in the £10 - £20 region (or even less if possible) and then something going up to perhaps £30/£35, and then something in the category up to £50 approx. Please also explain the pros and cons to help me decide. I will be most grateful for your help.
Thankyou.
Hi CaptainKirk!!
Try to check Dell they have good range of edar phones, you can choose the one that is suitable for you and your budget, they even provide some exceptional reductions on Dell coupon codes. I hope this helps!!
Thanks guys - I've ordered a pair of the Senheisers as they're too good to refuse for the price.
But I'm going to check out the Cedar ones too for another Media Player I've got.
