What is the minimum size 3D TV one needs to buy to appreciate 3d effect particularly watching live sports FAO Andy Clough
mchander
28
Hello
last year the smallest 3d tv one could buy was 40inch.
Now you can buy 3d TV in 32 inch
I want to know can one enjoy live 3d sports particularly football in 32 inch size.My room is not very big so i cannt think of 46inch upwards.
somebody mention that you cannt appreciate 3D effect in small screen so i am bit confuse whether shall i go for 40 inch or 32 inch size will be ok.
Please advise
Andrew Everard
1,878
It's really down to the distance at which you view the screen: I've found that 3D works best if the screen more or less fills your field of vision, as you're then not distracted by 'real' 3D objects around it. Turning out the lights is an alternative, but really the bigger the screen the better for a convincing 3D effect. If you like that kind of thing...
And the award for the longest post title goes too.....
def lugs
39
I am not a big 3D fan. I have a 42" TV watching from a distance of 1.8-2metres away. I viewed a bit of the wimbledon finals, this is the first time I have tried to watch 3D in bright daylight conditions. I found the 3D to give a fish tank impression - i.e. inside the TV it was 3D but nothing was leaping out of the screen. Even sitting closer it still was not too impressive. I also found the flicker just off my field of vision from the active glasses distracting.
I closed the second blind, stopping the sunlight from entering the room and the 3D effect really came into effect and worked a treat. Even sat back in my original viewing position. As Andrew mentioned above watching 3D in a totally darkened room enhances the 3D effect tremendously.
But as it was Tennis I didn't watch much more.
Andy Clough
776
I recorded the Wimbledon men's final in 3D but haven't watched it yet (been away). I'll have a look on my 40in Samsung tonight once the sun's gone down... and yes, I do know who won
I'd say for 1m distance 46" Screen and for 2m 55" screen - this is minimum.
I have a 46" screen and sit 2.2m away and it doesnt look good until im close up. sometimes things come out of the screen and it looks ok but from 80cm it looks so much better
For good 3D i would only suggest a projector and avoid Samsung C series as my 46c8000 suffers from crosstalk very badly during sky sports 3d broadcasts. BluRay is usually within tolerance.
I enjoy watching films in 3D but sports i prefer to watch them in 2D as all it does is increase depth in the tv
chebby
1,257
34
19,220
craigtumilty said:
I'd say for 1m distance 46" Screen and for 2m 55" screen - this is minimum. I have a 46" screen and sit 2.2m away and it doesnt look good until im close up. sometimes things come out of the screen and it looks ok but from 80cm it looks so much better.
80 cm?
So that's 31 inches viewing distance before the picture on a 46 inch screen looks it's best?
Crikey.
f1only
278
Blimey, going by that measurement i'm gonna need a tv measuring 144" minimum ( does anyone make one? ). I have a feeling that may be massively ( dont know thats oxford english but hey what the heck ) out of my price range, not to mention it will block off my exit through the main living room door, looks like a projector may be the next upgrade.
