What is better between a dacmagic or a nad c515
Hi to all..
I'm writing from Italy..excuse for my poor english..
To you, which is better sounding??
I have bought the number of WHF where is the review of CA340 VS nad c515, but I think that DacMagic is far better than Ca340..
Thanks a lot...
Dan
I haven't heard the NAD but the DC gets compared to ~1k players...
John Duncan
Not being funny, but the NAD is a much better CD player than the DACMagic...
I know others here have found great improvements adding a DACMagic to their existing disc player, but I'd only buy a DACMagic to stream lossless music from a PC, not to improve your existing CD player.
Whilst you may get slight improvements if you added it to your Marantz, I don't think it would be worth the outlay. If you used it to stream from a PC, however, it would be better than the NAD, in my opinion.
Gerrardasnails
295
JohnDuncan:Not being funny, but the NAD is a much better CD player than the DACMagic...
I think you should clear it up for our Italian friend that the DacMagic is not a cd player in case he thinks that the NAD could sound as good as the DacMagic can sound. Oops, I just did it!
John Duncan
Gerrardasnails:JohnDuncan:Not being funny, but the NAD is a much better CD player than the DACMagic...
Indeed, didn't mean to confuse. Mi scusi...
nads
JD I have to agreeish.
I could tell next to no difference between my Nad CDP onboard DACs and the Dac Magics (even though i was told that i should be able to hear a difference). , but when used with the Squeezebox i could hear big differences.
Thank you very very much at all. I really appreciated your helps...
I know that DM is not a cdp;
I've about 400 Cd's in my collection (rock, fusion, r&b, jazz etc..) and the same Cd's are also ripped in Flac format in my hard disk, so,, the DacMagic or a cd player like Nad 515 are almost the same to me
If I buy Dacmagic I will use my pc as source (with the Spdif optical output), if I buy a cd player, I will use my original CD
My doubt is: for the price of 300£, is better DM or Nad?
I know that I must to replace my amp
(is a modified nad 3020i with all capacitors changed with some new better specs others..) and sometimes i use the Yaqin because is a nice cheap tube amp that feeling greats with my Klipsch)
Thank you so much again!
dani
Gerrardasnails
295
danidan:
dani
Now you have explained yourself and that you will replace your amp, the DacMagic is in another league to the NAD.
