CnoEvil said:One problem with old speakers, is that the rubber surround on the Woofer gets dozed and loses its flexibility....this can be heard in bass heavy music, as it can make a sort of flapping noise.
lindsayt said:If overdrivern / drivern with a lot of clipping the insulation on the voicecoil of speaker drivers can melt from excessive heat, resulting in the voicecoil insulation rubbing on the magnets, which sounds like a horrible scratchy sound on bass transients. A replacement cone / complete driver would be the solution to that problem...
If overdriven / excessive clipping voicecoil wire can burn out - like an old filament light bulb. Voicecoil wire is hair thin. This results in a dead driver...
Some types of capacitors (found in the crossovers in passive speakers) can go off over time. Other types seem to stay within spec for decades. The solution to out of spec capacitors is to replace them. How easy this is to do depends on how easily accessible the crossover is and on soldering skills.
nima said:lindsayt said:If overdrivern / drivern with a lot of clipping the insulation on the voicecoil of speaker drivers can melt from excessive heat, resulting in the voicecoil insulation rubbing on the magnets, which sounds like a horrible scratchy sound on bass transients. A replacement cone / complete driver would be the solution to that problem...
Dead driver means what? No sound? And in first case scenario if voicecoil melts, that's also something that would be noticed easily?
If there is a fault in crossover element could result in simply speaker not sounding as good as it should - something not so evident as previous 2 options?
Vladimir said:CnoEvil said:One problem with old speakers, is that the rubber surround on the Woofer gets dozed and loses its flexibility....this can be heard in bass heavy music, as it can make a sort of flapping noise.
If they have rubber surrounds that's great. Problem is when you buy old speakers with foam surrounds that need replacing every ~5 years. Rubber, paper and cloth surrounds will run for 20 years easy.
Edit: Lindsayt beat me to it. 🙂
lindsayt said:If speakers were left in a damp shed and had paper based cones with rubber surrounds, I'd expect the surrounds to be fine, but the cones to be weakened. Wouldn't do the cabinets much good either.
Al ears said:lindsayt said:If speakers were left in a damp shed and had paper based cones with rubber surrounds, I'd expect the surrounds to be fine, but the cones to be weakened. Wouldn't do the cabinets much good either.
In his case the rubber perished and on playing them it split badly...
Vladimir said:Al ears said:lindsayt said:If speakers were left in a damp shed and had paper based cones with rubber surrounds, I'd expect the surrounds to be fine, but the cones to be weakened. Wouldn't do the cabinets much good either.
Which speakers were those?
