what cables and which for new rega tt
lucan
hi
have just ordered a rega rp3/elys2 tt to go with my leema pulse amp and dali suite speakers but not sure which cables i need and what the best cables to use
amp has phono in and phono ground ,any help or advice would be very welcome ,thanks
The RP3 comes with cables — there's no way to attach new ones.
There's also no ground on it as Rega turntables don't have/need them.
Good job - you can spend your money on vinyl 🙂
thanks for that i was worried my tt would come then would have to go and get cable for it,
and all you want to do is get it set up and play your records ,
thanks again:dance:
Just to clarify!
The RP3 & RP6 for that matter come with the same High Quality phono cables
BTW Enjoy you RP3/Elys 2 it is a superb TT.
Hope you enjoy as much as I did mine!
Had my RP6 nearly a week now and its blowing me away - love it!
