hi fi newbie:
i am just pondering really I love the setup I have but no that the Roksan Kandy K2 is a significant improvement, however I can't afford it's current price. So guys, can you recommend some second hand amps to me?
I guess my budget would be around the 500.00 mark
TBH, at that budget I wouldnt bother...
The NAD C352 is a brilliant amp and I think you'd have to spend closer to £1k to better it with your set-up.
The Roksan K2 amp would be a natural choice but I dont think it'd give you the same depth of soundstage the NAD does; you may even find it a little forward with the AE Neo 3 speakers.
The Rotel RA1520 would also be a consideration but I think it'd still be more of a sideways step.
I think really, after that and IMO, you'd have to look at amps like the Naim Nait XS or the Cyrus 8XP.
Have you thought about adding a NAD power amp to bi-amp instead? 2nd hand or ex-dem I'm sure you could find one within budget.
