Hello everyone,
Sorry I have not replied to this thread earlier.
With regards to fuses, it is always best to firstly check the manufacturers manual to see if it provides a fuse recommendation. If the manual does not state fuse requirement then you can check the fuse fitted to the factory supplied cable to see what has been fitted (as crusaderlord pointed out). However many manufacturers are now supplying 5A rated power cables as standard to save costs; and if the unit is internally fused then a 13A would be better with our power cables (which are rated at 20A-26A) than a 5A. To ensure safety it is important to always fit the correct rating of fuse. As always you can contact us for advice at any time.
With regards to replacing fuses, although this is a simple procedure should you need to replace a fuse then please contact us. Fuses vary in quality and performance and using a fuse of inferior quality could affect the performance of our power cables. We use carefully selected high-performance silver-plated copper fuses and offer a free fuse replacement service. There are two options: we can send you a replacement fuse; or you can return a cable back to us to have the fuse replaced (will also carry out a mini-service at the same time free of charge). If fuses keep on blowing then there is a problem (i.e., incorrect fuse fitted, component problem or power cable problem). In this case it is always best to contact us for advice and return the cable to us for checking.
Hope this helps.
Best regards,
Darren
