GREENWAY said:Hi - Thanks for your reply.
It is a phono amplifier, yes. And I already own it, just getting around to setting it up.
But the problem I have is this - The speakers and inputs / outputs. The wharfedales are active (with built in amp) and have only a single output. I have just been using them as studio monitors (XLR to mixer). The Denon has a L&R +/- input while the Wharfedale just has a balanced 1/4" / XLR or unbalanced phono.
(I read somewhere I could cut an instrument cable in two and use the 1/4" to copper wire... but that sounds pretty suspect to me.... I don't wish to blow any equipment! )
davedotco said:Stop. Desist, right now.
You quite clearly have no idea about what you are doing. You need to read up on line level connections and high level (speaker) connections.
You also need to work out the differences between what an integrated amplifier does and what a 'mixer' does. Do not try rewireing your setup until you have done so.
GREENWAY said:Hi - Have been using my Wharfedales as studio monitors for years and also running my turntable through a mixer to them. Thought I should fork out and get a proper phono amp. Is there anyway to hook up my speakers to this unit?
GREENWAY said:Hi -
GREENWAY said:davedotco said:Stop. Desist, right now.
In essence, what you are trying to say is that it is not possible. Yes, It IS quite clear I have no idea, otherwise I wouldn't be consulting people with more knowledge than I. And with great knowledge comes internet arrogance! 🙂
I'll just pick up some passive speakers for the Denon then and keep the Wharfes for when I rebuild my tower PC. The mixer is for the i/o soundcard. Cheers!
Crocodile said:As Proffski said, you could run them from the tape loop but it wouldn't be very efficient. You'd have no volume control via the amp & would have to alter volume on both speakers, which I suspect would soon become a pain. May do as an interim measure though. No idea why he's suggesting having cables made up with 75Ω RG59 though as regular phono cables should be just fine as long as you're not going over silly distances.
