Debating as to which pair to buy. Living in the USA but can't seem to find any reviews from people that have owned or tried both pairs of speakers.
Quick background. I have a house with plaster walls and hardwood floors. The room where the speakers will be located has 9 foot high ceilings and is 14 feet by 12 feet. Roughly 3 meter ceiling and 4.5 meters by 4 meter room dimensions. Have a pair of Jamo C 601 speakers that are ideal for this environment since they are neutral and lean a bit warm in the lower midrange region. But one glaring problem. They need to be placed two feet from the back wall (over half a meter) to sound right and project the right sound stage. I don't have the luxury of that kind of room in this house since it is pretty small. Even shaving a foot (one third of a meter) off the required space from the back wall that the speakers need will be a big help and allow me to properly place furniture and my CD case.
I've read the Dentons are warm and while they have a rear firing port, don't need a lot of space from the back wall to sound right. And the new 220 has the downward firing port and a rep with Wharfedale said they need only be a few inches from the back wall to sound great. I prefer a neutral to warm sound. Hate bright high end and boomy bass. Prefer subdued bass and a smooth high end and overall polite sounding speaker. Slightly forward midrange is acceptable.
I am using a Dayton DTA 120 T class amp. Very low THD and runs 40 wpc into 8 ohms. 50 wpc into 6 ohms. 60 wpc into 4 ohms. Very clean amp which easily drives the Jamo's which are 6 ohm and a sensitivity of 86 db. Will be using a Yamaha CD S300 CD player. Audioquest Type 4 speaker cables, Pangea 14SE power cables and Audio Art IC3 interconnects.
Can anyone with experience with both of these speakers offer some feedback as to which speakers would work best in that environment?
