Wharfedale Diamond 155 with Wharfedale Diamond 10.CS ?
bigup
Hi all
Im planning to upgrade to a 7.1 setup in a new home cinema room (projector)
I currently have:
Wharfedale Diamond 10.1 Fronts
Wharfedale Diamond 10.cs Centre
Wharfedale Diamond 10 Rears
BK Monolith Subwoofer
Denon 1911 AV Amp
As i want to go 7.1 i thought it maybe good time to upgrade the fronts to Wharfedale Diamond 155 floordstanders as they are a great price currently (plus saves me on buying speaker stands)
the plan is to move the 10.1 to rear sides, and the use the 10 as rears
my question is, would the Wharfedale Diamond 155 fronts work ok with Wharfedale Diamond 10.cs Centre speaker? i know they are not in the exact same range, but would it cause issues best avoided?
either that or i just buy another pair of Wharfedale Diamond 10 so will have them for the rear sides and the rears (on stands which need to be purchased!)
thanks
