- Aug 10, 2019
- 2,556
- 4
- 0
Hi I have got some cambridge audio s30's but due to the layout of my room I have not got any room to get stands for them. They are on top of my wardrobe at the minuit, which is probably the most resonant piece of furniture I could have them on! My tv is at the other side of the room and having the speakers behind you when using them on the tv isnt the best. My only other option is to get some wall brackets should I even bother or will they sound terrible they have rear bass ports aswell it is reccomended that they are at least 8cm from the wall behind
- Not realy ideal!
Would be great if anyone has any suggestions as to whether I should even bother with wall brackets
Many Thanks
Many Thanks
