Wall mounted TV, what to do with sky box and blu-ray player?
Hi all, I am decorating my living room and am planning to wall mount my tv above the fireplace, my question is, what do people do with their sky box etc in this situation? im looking for a bit of inspiration, i considered putting shelves next to the tv but cannot find any deep enough to fit them, I also considered some sort of unit but cant find anything, all i can find is basically tv stands, any help or hints would be much appreciated
thanks
Have you considered going wireless? Having a transmitter that supports 1080p will probably set you back a few hundred pounds, but the upside is that you can put your players anywhere in the room (for example, next to the seats).
Since you mention multiple devices, I'm guessing that you don't have an AV receiver or other hdmi multiplexer, which would make the solution even more costly. But look around for Wireless HDMI Extenders if you're interested.
