Virgin v+ connection to Yamaha V667
goalhanger
34
Hello chaps,
Got Virgin V+ yesterday ( good install contrary to lots of posts ) and want to connect to my Yamaha V667 Receiver . What is the best way , via the HDMI to the Amp then TV , or HDMI direct to TV and use optical to the Amp ?
I also presume that a Harmony One will control basics on the Virgin box ?
Thanks,
I may be wrong (and being a Virgin Service Tech, you'd think I'd know!), but I don't think you need the optical cable. I believe the HDMI does the lot.
I use Hdmi to the amp, then amp Hdmi to the tv, on the V HD box it works fine. Cant see it being much different to the V+HD box.
If you dont & you go the optical route via the TV optical out, the programmes shown with DD sound probably would'nt pass through the TV back to the amp in anything but stereo.
f1only:
I think the OP was suggesting using an optical cable between the V+ box and the amp - which is what I do, because my amp does not support HDMI. Either route works, I would go with the HDMI route - if it works, as this simplifies cabling and should reduce lipsync issues.
Sounds good to me - means I don't have to buy the optical cable. I still have speakers to get so am not using the amp at the moment .
Just waiting for Audio-T to get the Boston Acoustics in , but also noticed they have gone up to £409 on their website - not paying that so we will see .
Thanks.
Sorry didnt know it had optical out of the V+HD box & as previous post by scene
Try here for your Boston Acoustics.
I actually bought the Yamaha at Richer and it is a bit like a supermarket in there and I then heard that Audio-T take a bit more time with you - its also nearer to me
I will see when they contact me to say they are in stock !
Well got the Bostons and all going fine , even the sub was picked up by the set-up mike.
Only 1 problem I opted to get the optical cable, a QED one and it fits the Yamaha fine but it doesn't seem to want to stay in the V+ box output hole. It goes in but is very loose. Do you think this is a fault with the V+ box or am I doing smething wrong ? I presume the QED label goes upwards ie the little domed part of the connector .
Still getting sound but I presume only stereo and not 5.1 as it says on the V+ booklet .
Thanks.
