Vintage amplifier
aversaurus
341
91
18,970
In my time I've had lots of vintage amplifiers some recapped some original most sansui .
But I've never directly compared a full rebuilt vintage amplifier with a modern of the same quality.
Has anyone out there done this ? And what do you think ? modern sound or rebuilt vintage sound?
I am not so sure there's a huge difference in sound between old and new.
Take your pick really but beware old amps will wear out mechanically as well as electronically.
SteveR750
717
128
19,070
Having researched this, and chatted to a couple of electronics engineers who repair th9is stuff for fun, it seems that in general the early vintage Japanese hifi from the 70s and early 80s are all well built, good components, but pigs to work on. As they evolved, many of the brands moved their manufacturing overseas to Taiwan, China etc, and sourced cheaper, lower quality components, but the designs are easier to work on as they are better laid out and simpler designs. Some are noted as better than others, e.g. early technics, most of Denon up the 2000s are examples of better specced designs wrt to components, whereas NAD are viewed as cheap and inferior (so I avoided buying a used NAD for that reason). The main culprits are capacitors - electrolytic caps dry out over time, so their spec changes, until they can sometimes eventually explode (hello NAD), pots can corrode, become gunked up which often just requires cleaning.
More modern amps use a lot more SMD designs rather than through hole which are cheaper but not as durable apparently.
Reactions: WayneKerr
Friesiansam
1,113
921
20,070
Many SMD components are extremely cheap. 25 to 30 years ago I worked in electronics assembly. Small SMD capacitors, transistors and diodes were so cheap, that if you dropped one on the floor, it was more cost effective to abandon it and take another from the reel, as the time taken to bend down, look for it and pick it up, cost more than the component.
ASK THE COMMUNITY
