Vinne ting Sonos to Audiolab 8200cdq
I have connected the Sonos to my new Audiolab. However, I have to purchase a coax or opitcal interconnector to use the Dac in the cdq. Does anyone have a suggestion on which input and cable I should use?
... And does anyone know how to turn off the annoying autodictionary on the iPad? Vinne ting = connecting
scene
For the sonos, I'd use an optical cable. It probably won't make that much difference and a decent, short length of optical is cheaper than a good coax.
As for auto correct, it can be good, or a bit of a pain. If you notice it doing something odd, you can press the little circled x that appears at the end of the road to prevent it autocorrecting.
