VHS to DVD any Players under £150 ??
Hi There I have stacks of old VHS tapes i would like to keep and put onto DVD - are there any good Combi`s out there around the £150 mark or under.??? cheers
I used a Panasonic VHS/DVD/HDD/Freeview combi when I was migrating from VHS. It is still going as one of my daughters uses it as her DVD player. Very reliable and well made with a good picture especially with upscaling.
Superb machines. Worth finding a bit more money for.
get a capture card and then record ur vhs to ur pc then burn to dvd if u want
Cheaper than those, but more long-winded, is the Ion VCR to PC kit, from there you can burn them on your pc to dvd.
http://www.google.co.uk/products/catalog?q=vcr+to+dvd+ion&oe=utf-8&rls=org.mozilla:en-GB😱fficial&client=firefox-a&um=1&ie=UTF-8&cid=18228084957029131705&ei=ccQXTK7uFY-F4Qa6rOmBDA&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDEQ8wIwAg#
Video capture via USB dongle is definately the way to go - I'm assuming here that these are tapes of TV recordings and camcorder stuff and not copy protected (macrovision).
I did it years ago and struggled because of disc space (had to capture 30 mins at a time!), but now when you can get a 1TB hard drive for £50 you can burn til the cows come home. Also with all the DVD authoring software out there as well as highly capable compression codecs you can't go wrong.
Cheers, Nick
