- Aug 10, 2019
- 2,556
- 5
- 0
Hi I have a musical fidelity Vdac, which I am using with the following
Arcam CD73T Opto digital
Denon TU1800DAB tuner coax digital
Imac USB.
The problem I am getting is when the Imac is connected via USB I am getting some noise from the Imac / earth loop. I am using a 5 meter usb cable ( cheap cable, but it digital). Is there anything I can do to cut the noise, the DAC and all HIFI is plugged into a tacima mains filter. The Imac is not , but I am not sure that will help, I guess its from the Imac psu.
As I am not sure the dac improves the Arcam , I am think of using the Mac via my airport express into the Vdac opto, which will be ok.
Has anyone got any other Ideas ?
Imac USB.
