ALZI1969:..... THE ONLY ONES I CAN FIND ARE MORE OR LESS FOR PRINTERS ETC......
They are the same, USB A, the flat connector for the PC end and USB B, the more square end for the printer or DAC. That can also be a USB mini B, depending on the DAC.
ALZI1969:..... CAN ANYONE GIVE ME ADVICE ON A GOOD 5 METRE LENTH USB THATS DESIGNED FOR THE JOB...THANKS.....
If you have a well made 5 metre USB printer cable lying around, use it. I bought an Oehlbach USB off Amazon and can't say I heard any difference from the too short printer USB I used at first. My thoughts on the issue are; find a well made cable with a good tight connector and it will do as good a job as a named brand, premium priced product.
