Upscaling question
I have both a Sony KDl32d3000 TV and a DAVIS10 DVD player. They are both connected via HDMI and as far as I am aware they both upscale. My question is this. Which one does the upscaling and would it be better (or possible) to let one of them do the upscaling but not the other? Confused!
If your video output from your DVD player is set to 720p then it is the DVD player that is doing the bulk of the upscaling leaving a very small amount for the TV itself to do to fit the screens resolution (I think I am right in taking your screen as HD ready) this generally will give beter results this way as its leaves the TVs picture processing software less work interpolerating those missing pixels.
Thanks for that. The screen is HD ready and at the mo the DVD is set to 1080i output so I will change it to 720p and see what the results are.
