Upgrading my desktop setup
Ok so I've really become interested in upgrading the set up that I have at the moment and am willing to spend some money on doing it.
I bought a pair of Grado SR80i headphones the other day and now want to add to that. My current set up is:
I use my desktop PC to run everything (music wise) and I'm using the Creative Soundblaster X-fi Xtreme audio sound card I have (brand new around £40) with some Logitech Z4 speakers plugged into it and then I plug my headphones into the speakers headphone port when I want to use them.
So I was wondering where I could go next...
I was thinking of buying a headphone amp/DAC ??
What do you think?
Any help is much appriciated
Definitely a headphone amp/DAC, but what is your budget and do you want to upgrade the speakers as well as the headphone listening?
Budget around £150
And if I could make both the headphones and speakers better then i shall be very happy
I know that a headphone amp can really make good headphones shine but I'm not going to be changing my speakers anytime soon (I can only run a 2.1 setup on my desktop and I like the Z4s) so if I can do something to them as well at the same time as the headphones then this will be a real bonus
The best way to improve the speaker sound is with better stand alone active speakers or connected a DAC to an amp that has a headphone output. But as the budget is £150 and headphones are the priority I would start with an amp/DAC.
Your get headphone amps with DACs such as from Firestone Audio and DACs with headphone amps such as from Beresford. I would also consider portable amp/DACs such as from iBasso which can still be used as part of a desktop system.
I cannot recommend any over anyother as I have not heard anything outwith Firestone.
What would be the best option though?
To save up more and buy a DAC and an amp so then I could use that for both speakers and headphones
Or just buy a headphone amp and then upgrade from my Z4s later on seperately
Sound wise it is very difficult to tell. Using a integrated amp you are using your computer as the source for a traditional setup. Getting a headphone amp/dac and say speakers such as the B&W MM1 (which also has a headphone out) or active speakers such as by Gelenlec, Epoz or Yamaha as an upgrade form your Logitechs is less traditional, and arguably less compromised.
I'm new to all this so bare with me if I do not understand fully
So what you're saying is I get a headphone amp now e.g. i was thinking this
http://www.beresford.me/products/TC-7520.html
Use that with my headphones til I save up some money and buy some speakers to connect to it ye?
