Upgrade time SCLX-57 or RXA-2020
pete.g
33
Has it really been 4 years since I bought the denon avr2310?
well it's time to upgrade I feel, and as you can see I've narrowed the field to to the above mentioned Pioneer and Yamaha.
the added features on both are very impressive and I definitely need the dlna/airplay streaming capabilities
firstly, can I presume the improvement in SQ would be substantial over the Denon? The extra power should see to that.
Secondly is the price difference. The Yamaha is £300/€400 more expensive. Is it worth the extra outlay?
as usual, all input is appreciated
regards
peter
Nintendologist
19
I'd be careful when you expect sound quality difference. I demo'd a Yamaha amp on B&W CM series and although the steering and surround sound effects in movies was much better than an old Denon 3803 I had, the music reproduction was very bright (to the point I found it painful to listen to... I do list quite loud sometimes, mind). I wouldn't say it sounded 'better'.
Same speakers, I heard the previous Pioneer LX56 and despite a few reviews saying so, I didn't find it bright or difficult to match with the B&W speakers.
Mind you, saying that, I bought an Arcam AVR in the end as it suited my situation far better.
mr malarky
111
I went from a denon 3310 to a pioneer 75 last year and there was a noticeable improvement, so I would expect you'd see a marked difference going from the 2310 to either of the models you mention.
