Upgrade Advice please
jodaki
14
Ive got a small setup that I want to improve. It looks like this:
- AE1 Active speakers
- Linn Intek integrated amp
- Planar 3 turntable with a Rega Exact MM cartridge
- Marantz CD6007 CD player
- Old Denon Tape deck.
To clarify, I use the Intek (which is 35 years old!) as a preamp, then I line out to the speakers.
I mainly play Vinyl so that is what I want to improve the most. Im aiming eventually for an entry-level-high-end system (total system cost between £5k-£10k). I want to upgrade gradually over the next 5 years or so. Im aware that significant upgrades from here get pricey, so I want to get the best bang for my buck upgrading one component to the spec Im after. Or should I just stick to what I've got until I've saved enough to buy a whole new system?
The upgrading advice I've had so far, in no particular order is:
- get a better cartridge
- get a phono preamp
- get a better amp
- better turntable
- better speakers
Which if any would give me the biggest benefits and would fit the overall plan of achieving a basic high-end vinyl-focused system?
thanks, John
- get a better amp
- better turntable
- better speakers
thanks, John
Interesting.
If amp is perfectly serviceable why active speakers?
This could hinder future upgrades.
Are you happy with speakers in your listening room?
A phono preamp will not really help matters as you will still need to keep your amp as the preamp and you're going to have to spend a fair bit to better the internal phono preamp it has.
Concentrate, as always with a vinyl based system, on the source first so replace the cartridge with something better. The Exact is pretty good but think you could do better.
Personally I would stick with what you have until you can buy a complete new system that you can audition all together.
Reactions: jodaki
Interesting.
Thanks for your reply. Trying to remember - I think I was influenced by What Hi Fi reviewers who said they were a very good option for a mid-range system. Maybe that was a mistake.
A worthwhile step up from your Rega is going to need some spending, and very careful auditioning. The obvious route would be to go up to a top-end Rega, but other options are available.
I would start with a new cartridge and take it from there. You may need to buy some Rega arm shims to adjust the VTA depending on what cartridge you choose.
Reactions: Entrigo
I would agree and suggest, if it's going to be the main source the OP moves up and away from a Rega deck to something more flexible when it comes to upgrading.
If his amp is sound I would keep it and sell the active speakers to go for some passive alternatives.
Reactions: matthewpianist
Possibly, don't know why you just didn't go for the passive AE1 when you already had an amplifier.
What size is your listening room?
Active speakers with an integrated amp? Utilising pre-outs on the latter presumably?
I'd upgrade your deck, cartridge and get better actives. The AE1s are great, but you've got heaps of options with that budget. Maybe even chat to a couple of dealers that do a bit more than just Rega, Project, etc. You're into Acoustic Signature, Nottingham Analogue and Origin territory now. Check your options accordingly.
- get a better amp
- better turntable
- better speakers
thanks, John
Rega P3 is a decent deck, but depending on the age, you might want to upgrade to a newer version? But improvements in SQ might be marginal. A good upgrade would be the P6 with an Ania MC Cartridge - that would also require a MC phono stage and would likely set you back £2.5 if you go with a budget phono like the Rega Fono MC - more if you want a MM/MC phono. In that case I warmly recommend the Simaudio Moon 310LP - I have the 110 and it is very good (but of course, there are many options available).
Or you might want to go with a totally different turntable. A good option could be a Technics SL1210GR - despite the "DJ look" might not appeal to everyone. It's direct drive turntable so more reliable speed and accuracy and easier to interchange cartridges. Once again, you'd be in the £2k park, although you can find cheaper ones second hand.
In any case, definitely consider carefully your next step in terms of turntable before upgrading cartridge.
As well as the turntable, I would first of all change speakers to a good quality passive pair. I am not very technical but I suspect the output of the amp would be too high for the speakers, resulting in distorted signal and potentially damaging the speakers in the long run (you are at all effects "double amplifying" the signal).
Interesting questioning but what a budget !
I am facing quite the same quest with less money.
From my readings, I've gathered that it is crucial to prioritize the chain from the record to the speaker output. This means placing significant emphasis on the cartridge in perfect harmony with the tonearm, followed by the preamplifier and the amplifier.
If you are happy with the cartridge (or if it's new), for sure the weakest point would be the phono stage.
These references are leading the market for years but I have no clue on which one to select for your application/equipment. Just some good phono stages you can read a lot on WhatHifi and forums (warnings about prices from 200GBP to x2 or more).
  • iFi Audio iPhono3 Black Label: why not?
  • Graham Slee : why not. Can be found at 500€ or even less.
  • Moon 310 LP (V1 or V2): super interesting but pricey to me
  • Octave Eq2 : super interesting considering form factor and neutral color.
  • Goldnote PH5 : super cool form factor but the screen is useless for me.
  • Heed Quasar + QPSU: Nice form factor but no clue on the results.
  • Lehmann Black Box: Compact. Could be good.
  • Aurorasound Vidaprima: Too much expensive to me. No settings.
  • Jolida : Why not? But difficult to find one used.
  • Ear 834P - with tube. Seems to have its own color. I do not want that.
Cannot find a small one made in UK for roughly 150GBP with a wooden front panel. Comments are really enthusiast. If someone has the ref... thanks in advance.
edit : found!
