TX-P50VT20B
Hi Guys,
Can anybody recommend a good, reasonably priced (<£100) 2.1 system to be paired with my new TX-P50VT20B, as the sound output from this TV isn't great.
Also, does anyone else that owns this TV notice a buzzing noise when the TV is on?
Many thanks,
Lall
do you have your hifi gear in the same place as your tv? if so i think you can connect direct from your tv to your rotel using analogue interconnects there's Analogue Audio Outs, left and right on the rear of the vt20..
not 2.1 but it would probably sound alot better than a £100 2.1 system..
Unfortunately not. My Hi-Fi setup is elsewhere, else that's exactly what I would have done otherwise.
lall360:
ah, i should have realised judging by the kit you've got listed that you would have known that
perhaps a cheap 2nd hand stereo amp and small speakers from ebay?
I know mate, I think that's what I may end up doing. Although I have seen some 2.1 systems from JBL, but didn't know if they were any good. The research continues! Cheers for your help 🙂
