- Aug 10, 2019
- 2,556
- 5
- 0
Hi all,
I want to get the optical source from my tv and optical source from my airport express into my dac. The dac has 1 optical in and 1 co-axial in with a switch. Is it best to:
a) get an optical switch box - both optical in (buy a switch box and 2 optical leads)
b) get a optical/co-axial converter for the tv (buy converter, co-ax cable and optical cable)
c) just use RCA out of the tv into the amp (buy 1 set of 1.5-2m RCA cables) I have tried this with some maplins interconnects and the sound is sibilant
I do not want to loose any quality from my music (ae), with the tv sound being secondary. I also want it to be cheap. What do you recommend?
Many thanks, Lee
Many thanks, Lee
