- Aug 10, 2019
- 2,556
- 4
- 0
On my project 3 turntable, the sound quality deteriorates as the stylus gets nearer to the centre of the disc. Can anyone advise me on the likely cause?
thanks
Vonspritz
thanks
Vonspritz
That's interesting. I have the Debut 2, and the instructions tell me to use the third groove (instructions are pretty pants, to be honest). But I always though it should be the middle groove, based on the spec of the OM-5E cartridge.True Blue said:Agree with all above, also while your at it check your tracking and in particular your antiskate setting
see here
Also you dont mention if its an original fit cartridge or a new one? Again please pay particualr attention to the above.
No, you're right Lambda. If it's only happening on a couple of records it's not IGD, it's that the records are knackered.lambda said:I noticed I get this on a couple of my records too, but it's always in the same place and always on the same records. I just assumed that because they were old records they'd surferred abuse in the past?
I concur. I've got one of these Knosti's and they are a really cheap and effective cleaning and anti-static solution. Compare how much dust a non-cleaned LP attracts against one that has been cleaned with a Knosti. A real "Night/Day" difference.DandyCobalt said:For cleaning (and removing static- my biggest problem). Try this http://www.amazon.co.uk/CONRAD-Disco-Antistat-Disco-Antistat-Cleaner/dp/B000BFXIVW/ref=sr_1_1?ie=UTF8&qid=1313831965&sr=8-1 Seems to work very well, and quite therapeutic on a Saturday morning.
Chris, I don't think you got an answer to this.lambda said:What symptoms would I get with too much anti-skating?
In addition to a cleaning, I'd also like to store my LPs properly, most come with rubbish cardboard sleeves. Can I get anti-static sleeves for the vinyl and plastic covers for the LP covers? Would this make a difference too?DIB said:I concur. I've got one of these Knosti's and they are a really cheap and effective cleaning and anti-static solution. Compare how much dust a non-cleaned LP attracts against one that has been cleaned with a Knosti. A real "Night/Day" difference.DandyCobalt said:For cleaning (and removing static- my biggest problem). Try this http://www.amazon.co.uk/CONRAD-Disco-Antistat-Disco-Antistat-Cleaner/dp/B000BFXIVW/ref=sr_1_1?ie=UTF8&qid=1313831965&sr=8-1 Seems to work very well, and quite therapeutic on a Saturday morning.
You can pick up anti static sleeves off Ebay quite easily, lots of choice out there. I've replaced quite a lot of my old non anti-static/cardboard inner sleeves with new fresh anti-static ones. I tend to replace them as and when I give the LP a good clean. Well worth the relatively small outlay.lambda said:In addition to a cleaning, I'd also like to store my LPs properly, most come with rubbish cardboard sleeves. Can I get anti-static sleeves for the vinyl and plastic covers for the LP covers? Would this make a difference too?DIB said:I concur. I've got one of these Knosti's and they are a really cheap and effective cleaning and anti-static solution. Compare how much dust a non-cleaned LP attracts against one that has been cleaned with a Knosti. A real "Night/Day" difference.DandyCobalt said:For cleaning (and removing static- my biggest problem). Try this http://www.amazon.co.uk/CONRAD-Disco-Antistat-Disco-Antistat-Cleaner/dp/B000BFXIVW/ref=sr_1_1?ie=UTF8&qid=1313831965&sr=8-1 Seems to work very well, and quite therapeutic on a Saturday morning.
Yes, totally agree. Much easier to handle than the similarly priced Nagaoka, good though they are.mitch65 said:I swear by MFSL inner sleeves, you can get them for 20 quid for 50 delivered from juno.
