Turntable and system for a beginner
Right,
 At the moment, I have my Uncles Sony XO-750W (I think) plugged into My XBox 5.1 Surround sound system. Its not very loud, does anybody know why it might not be as loud as my MacBook is when plugged into the same Surround Sound?
Thanks, Jake
Henley
The chances are that your Sony unit has a phono level output that is far lower than the standard "line level" used by most other components. You may need a seperate phono stage for this to work correctly.
d4v3pum4
40
You will need something like THIS for it to work. Richer Sounds sell a cheaper one which should do the job with a gaming s/s system.
What is a seperate phono stage?
ÿAlso, If I wanted to get a full new system, what would I need? ( I will only need it to play records and possibly plug my Macbook into)
ÿ
Thanksÿ
