As the title says, does it make any difference? Since TRS is balanced and RCA is unbalanced, does TRS work better?
TRS is just a 3-pole connector.As the title says, does it make any difference? Since TRS is balanced and RCA is unbalanced, does TRS work better?
I'm sorry what is it that you're asking? Connectors? Balanced v unbalanced? If so in regards to what? Sound quality?
It might be obvious to others but I'm only about to have my first coffee of the day.
Yes, TRS always unbalanced on headphones.TRS is, I think, usually unbalanced as is the case with 3.5mm and 6.35mm TRS terminated headphone cables.
There would be no advantage in using TRS over TS if you are connecting it to a single RCA plug.
What is the socket you're plugging the jack plug into? Balanced or unbalanced?
I know nothing about pro gear...Yes, TRS always unbalanced on headphones.
But 6.35mm TRS balanced is often used on pro gear (and the odd domestic powered speakers of course).
....more than some of the 'pros' using the gear, I'd betI know nothing about pro gear...
Nothing wrong with your setup, all very nice.Thanks for that!
I’m connecting scarlett 2i2 3rd gen’s TS/TRS* output to Fiio K5 Pro RCA input. Then using Edifier S1000DB native RCA cable connect from Fiio K5 Pro to the Edifier’s input.
I’m thinking of upgrading the native RCA cable to something better, will it worth it or just use the native cable? Any recommendations sir? Is there anything wrong with my setup maybe? 😊
*I read the manual it says it can be connected balanced/unbalanced.
Why not go from Scarlet 2i2 directly to your monitors? You'll need a pair of 6.35mm TRS to XLR cables. This way you'd be running balanced from DAC to monitors which is preferable.I’m connecting scarlett 2i2 3rd gen’s TS/TRS* output to Fiio K5 Pro RCA input. Then using Edifier S1000DB native RCA cable connect from Fiio K5 Pro to the Edifier’s input.
Okay… I was expecting a better sound quality if I upgrade the cable to Mogami with Neutrik TS and Amphenol RCA. Will it? 😊Nothing wrong with your setup, all very nice.
Unless you need a different length, or fancy a different colour, the Edifier cable will be perfectly OK 👍
After reading this I think it is a very good idea but then I go search for the manual the make sure if it possible, seems like it’s not? Since the XLR is for output to the passive speaker, can it be used as an input?Why not go from Scarlet 2i2 directly to your monitors? You'll need a pair of 6.35mm TRS to XLR cables. This way you'd be running balanced from DAC to monitors which is preferable.
Then if you're intent on having Fiio in the chain use headphone out on your Focusrite (though at that point you might just plug your headphones in directly to 2i2).
Has the Edifier got a balanced input?Why not go from Scarlet 2i2 directly to your monitors? You'll need a pair of 6.35mm TRS to XLR cables. This way you'd be running balanced from DAC to monitors which is preferable.
Those that expect a better sound, often 'hear' it , so if you've got the money.......Okay… I was expecting a better sound quality if I upgrade the cable to Mogami with Neutrik TS and Amphenol RCA. Will it? 😊
Hahaha what do you think? Will it in fact product a better quality with the interconnection upgrade? Are you a hi-fi enthusiast? Maybe you can share your setup so we can learn from it for further upgrades 😊Those that expect a better sound, often 'hear' it , so if you've got the money.......
My bad...Has the Edifier got a balanced input?
(I didn't think it did have).
Yeah, my bad. Just noticed you couldn't go balanced. If it was possible I still would as many USB interfaces will transfer a lot of noise from PCs when used un balanced. I know my Audient ID14 does, so that would be preferable for me even for short runs.This is the best way to do it, but as the speakers don’t have XLR input, you’d go from 2i2 to speakers via TS (or TRS) to RCA. but whichever you go for it won’t be balanced as RCA is not a balanced connection. For a cable run of reasonable length, I wouldn’t be concerned about using balanced at this level.
If you wanted to upgrade your 2i2 to a different interface with coax and go digital to the speakers.
Sorry for getting your hopes up. You will need to use RCAs. No way to go round itAfter reading this I think it is a very good idea but then I go search for the manual the make sure if it possible, seems like it’s not? Since the XLR is for output to the passive speaker, can it be used as an input? View attachment 2651
It doesn't matter what I think.Hahaha what do you think? Will it in fact product a better quality with the interconnection upgrade? Are you a hi-fi enthusiast? Maybe you can share your setup so we can learn from it for further upgrades 😊
Thanks for your insight sir, this help me made up my mind. I will not upgrade those cabling for now as it all sound pretty good. And I bet even with those upgrade, there will be very minor to no improvement since all my equipments are side to side so the native RCA cable connection should be okay! 😊It doesn't matter what I think.
Have a look at a cable debate on any forum. You'll see that opinion is divided.
I can tell you that I own a 0.5 metre twin RCA interconnection cable that retailed for £76.
Does it sound any better than a £2 cable?
Not at all. But I got it free, won it as a prize.
If I'd been stupid enough to pay £76 for it, I might well think it was the best thing since sliced bread.
No harm in buying good quality connectors, especially as you mentioned making your own leads - they can be nicer to solder, have better cable clamps etc....so your leads should be durable and stay working for ever.
As for sounding better.......no.
