T
the record spot
I was reading up on the tech specs on one of my amps, Sansui's AU-217 on an Australian website, and - as with a few of the amps in the AU range, it's conservatively rated at 30wpc (the Mk II was 40). The site then goes on to say that the Damping Factor of 80 (as per the tech spec) has an impact and hence the wpc rating is probably somewhat higher. I'm interested to know (from a layman's POV) what the DF does to the power output rating as the Wikipedia entry seems to suggest it relates more to an interaction with speaker cone movement?
