What connections are on the back of each unit? Pictures?
Sorry no pics at mo., Think the recorder has European plugs called DINS, its got 2 choices, dont know which one to connect to. She wants to use the old amp if poss, it has RAC plugs in the back. Can i buy a cable to fit both ends???What connections are on the back of each unit? Pictures?
We have several old tapes which when machine is switched run from one tape to other.I suggest getting hold of the tape machine, and some tape, to see if it functions at all. Sadly, it’s highly likely to need ££ spent to get it working, unless you know otherwise.
The 2-pin DIN sockets - flat and round - looks a bit like plus and minus - are for loudspeakers. That’s if it’s a Beocord 1600.
corrected for you.I am not too sure the Beocord 1600 had any outputs apart from the speaker connections, so I don't believe you can connect it to the amp.
it has two line level inputs so the turntable could be connected to it using a phono preamp.
As stated you then wouldn't need the amplifier
much obliged, lack of sleep so not a good time to be on the forum I guess....corrected for you.
