Tannoy TS10 is it worth it???
sta99y
137
Hi all,
Tannoy TS 10 £190 is it worth it? Or should I consider MJ reference 100 MKI £150 ish, BK Gemini II £214, or Rel quake £150ish
Pls help me choose to fit in with components in my sig!!!
Would the tannoy not be better having more power to call upon when needed?, WHF gave it 5*'s and the BK only 4*'s, it does make you wonder....
The Tannoy is a more all rounder IMHO better with music, where as the BK is more a home cinema Subwoofer. In the end decision is yours of course, dependant on your listening tastes / preferences.
How about a Monitor subwoofer at a good price to go with your other speakers, so possibly This used subwoofer may fit the bill? & a link to specs
Regards
Regards
I have checked this out but I think it's 8inch and on the small side.
I really am thinking of the Gemini 2 in oak tbh. 2yr warranty and all that. It is mainly for movies.
Thanks F1
