Right I’ve basically read my SVS subs manual and my Yamaha A-S3000 manual but still not sure if I’ve made the right connections or not .
I am meant to use the Pre-outs on the Yamaha A-S3000 which would mean I would be using the L+R connection using RCAs on the Pre-out section on the back of the Yamaha .
On the SVS SB2000 subwoofer I have a section called OUT : line level L+R and the other section which is called IN : L+R but the R / LFE
Now with the home cinema connection I just use a single connection on the IN R /LFE which leaves L in the IN section which I’ve used a single connection from there to the Yamaha but the Yamaha uses L+R connection on the Pre-out section this is the bit that’s confusing me because on the Subwoofer end I am not making a L+R connection only a L .
Now I am getting bass coming though the sub from the Yamaha but it’s just thoses things I’ve mentioned above that’s confusing me to no weather I’ve made the right kind of connection as I am pretty sure it should be a L+R connection on the sub and the Yamaha Am I wrong or right ?
Anyway I thought I would try to find out what the sub will do with music but I also need to keep the connection for the home cinema so I kind of want to share the sub with 2 channel music and also for home cinema which is already sorted on that front .
