Question Suggestions for Acoustic Energy AE209 replacement tweeter
Shotokan101
Pair of AE209 floorstanders, one of the tweeters is irreparably damaged, so looking to replace both with anything suitable.
Anybody have any suggestions?
Thanks,
Jim
Thanks,
Jim
Well first of all I would try contacting Acoustic Energy as they're usually, from what I've heard, very helpful. They may be able to supply a replacement or tell you what make and model they are so you can try to find one from the manufacturer or a DIY stockist. If they're no longer available I would contact a supplier such as Wilmslow audio who supply drive units and kits and may be able to supply a close match if not the original type. If you just get any right size tweeter then you run the risk of it being a poor match for the crossover so it could change the character of the speaker which would probably be for the worse.
Are your tweeters the type with a little triangular guard over the front? If so, a pair of AE109 sold on Ebay recently for £40, so a secondhand route might be a thrifty option. And that also tells us that larger expenditure probably isn't a good investment.
However, I agree, get in touch with the manufacturers first.
