Subwoofer question
Are all sub's active?
Is it ok to fit an active sub to a receiver?
I have no idea about them as I get all the base I need from my floorstanders.
piobob: Are all sub's active? No some sub's are passive,but passive sub's are usually found/used with home cinema in-a-box type system's.piobob: Is it ok to fit an active sub to a receiver? Yes, you just connect from the receiver's sub out to the sub's low level input.or alternatively wired in parallel with the front l+r speakers then connected to the sub's high level input if it has them.
Thanks for quick reply Dave.
I asked this question because my son has a new Onkyo 507 which I will be helping him to set up.
He had a Panasonic all in one surround system (don't know which) with a Subwoofer, but not sure yet if it is active or passive.
Would it be advisable to connect a passive (if it is) to the 507, or would it drain it too much?
