B
BIGBERNARDBRESSLAW
I've had my Tannoy TS2.10 for quite some time, but I wasn't 100% sure if I had it setup properly, so I've spent a bit of time, checking I had it connected correctly, and that I had all the levels where they should be.
I'm almost happy, but there's just one thing that's still leaving me a bit confused. The receiver (Yamaha RX-A2020) has a setting where I can have either normal or reverse phase, and there is also a knob on the back of the sub where I can adjust phase from 0 to 180 degrees.
I'm presuming 180 is reverse, so what's the difference between normal and reverse phase? If I choose normal on the receiver, should the sub be set to 0 degrees, and if I choose reverse on the receiver, should the sub be set to 180 degrees?
Your help as always is much appreciated.
