Sub for PMC speakers
I've just ordered some GB1i/DB1i speakers but am now looking for a suitable sub. What would you recommend? I wish I could stretch to the TLE1 but the wallet is already considerably lighter!
Nice1! Good choice.
I know the TLE1 is expensive but it's PMC.
The TLE1 blends in smoothly with my FB1i's, if you can stretch your budget then go for it ;-)
Bet your neighbours love you.
Well they have a drum kit in the garage so I only think it's fair they have some competition ;-)
I only bought the sub for movies and glad I did, with the crosssover set at 40Hz the FB1i's do most of the work but the TLE1 handles sub bass smoothly
If you are more of a music fan and not bothered about sub bass I would spend the money elsewhere.
... either way good choice and hav fun with ur PMC's
I'm thinking of waiting till I have the speakers rigged up and seeing how it sounds. I watch alot of old movies and play music through my Arcam gear so the sub probably isn't so critical.
Save up would be my recommendation. It will cost you more in the long run if you compromise now.
