Since mid last year I am looking for a pair of good in-ear headphones. Requirements:
- excellent sound (possibly multiple balanced drivers)
- either included custom fit or optional custom fit tip that can be ordered separately
- must be very durable, have detachable cable, 3-button ipod control (can be bough separately)
The problem I am facing is lack of possibility to try before buying. As this kind of 'phones start at abt 70 and go all the way to more than a grand, I want to see for myself and be sure of my choice. Which means, it seems obvious, that I want to listen first to at least 2-3 candidates and then chose the one I think has the best cost/sound q ratio. the question is how do I do that?
I have been around many shops in London - no demos found. (Micro Anvika used to have good range of Shure models on demo with disposable foam plugs + wipes - but not any more).
I e-mailed Shure UK several times asking if they have info on who has demo kits. No reply.
Can forum members help with any practical suggestions?
Can WHF help? would this be savvy enough for the 'savvy shopper'?
I may go to the Bristol show to see if there is anything on demo there.
