Streamer for Plinius 9200
n4d5
54
I would like to add a music streamer to my current setup composing of an Plinius 9200 amplifier, Pioneer PD-S703 CD player, PMC OB1i speakers.
I currently use my phone to stream Spotify or Tidal through a bluetooth adaptor connected to my amp through a 3.5mm cable to phono. I feel the sound is lacking and i'm not getting my most out of my system.
I have a budget of £1,000 to spend on a streamer or i'm open to alternative ways to stream music.
I also have a Chord mojo sitting around, could I use this in anyway ?
Recommendations and suggestions would be greatly appreciated.
Thanks.
Vincent Kars
315
299
2,270
If this is true, using the turntable input, the sound will be horrible.
But some use phono for RCA plugs :)
As you have a Mojo, connect it to the USB of your phone.
This will tell you what you can expect by upgrading from Bluetooth to a lossless connection with a good DAC.
tsaoandy
14
6
4,525
Thanks.
Hi
I don't like adaptors, they get in the way.
I have heard Cambridge sound in the past, but I haven't heard the Cambridge DAC 200M, it's pretty good value for being very versatile, you might want to check it out, it comes with bluetooth and it accepts Tidals' MQA files, as I haven't heard Chord Mojo either but read some positive reviews so I guess it's a decent DAC, personally I believe whether or not you are using a streamer, DAC is part of the chain anyway, so better quality the analogue output on the DAC, better the sound.
I owned Plinius 8200 mk2 before, I was very close to upgrading to 9200, I really like Plinius but they are too expensive the current amps.
Andy
muljao
334
90
10,970
Blusound node 2i is well within budget. However you could in theory buy a relatively inexpensive streamer an hook it up through the mojo as long as it does what you want and has an optical output
insider9
1,182
641
12,070
OP, since you already have Mojo I would actually hook it up to a laptop. Setup Daphile running off a USB stick and try that before you spend any money.
Streamers are a minefield in my opinion. Hard to get a good combo of amazing software and hardware. Usually one is lacking. And spending a grand on something new not knowing all the pitfalls may be a rash decision.
