- Aug 10, 2019
- 2,556
- 5
- 0
I have a bit of a weird one here that I can't seem to be able to fix.
My rear left speaker works and sound comes out of it as it should, however my right speaker sounds much better. They are both 1.90m away from my position and I have the distance inputted into my Denon 1910.
I have also got an SPL meter and calibrated the levels of the speakers so they sound the same. I have only recently noticed the left speaker not sounding right so I switched them out and the same thing applies so its not the speaker itself.
I have them wall mounted quite high above my head pointing downwards, both are at the same angle. Its weird I'm sure this didnt used to be like this otherwise I would have noticed, so I cant understand what has gone on.
All I can say is that the rear left speaker sounds somewhat like it lacks directionality. The right speaker stands out like yes that is the right rear how I like it the left one does but to a much lesser degree.
I have also checked to see if the speakers are wired correctly which they appear to be. The only differnece between the speakers is the left one is above a door and the right one is just wall. However if this was the problem I would have noticed this before now, its winding me up because I can't get it to sound right.
I dont have any of the audyssey stuff setup so its not that either.
Cant fathom it
I have Q Acoustics 1050i fronts bi-amped
1020i rears
1000c centre
1000s sub
Cant fathom it
1020i rears
1000c centre
1000s sub
