I get a terrible hiss when listening to music on my dell laptop using headphones! What is the best affordable way to avoid this hiss and improve the sound quality? It is mainly for listening to spotify / iplayer in work with £20 earbuds and £100 cans at a low volume. I don't need anything special, just something reasonable.
I came across the "FiiO E7 USB DAC and Headphone Amplifier" on Amazon for £65. Is this the kind of thing I should consider buying?
http://www.amazon.co.uk/gp/product/B003VO75V4/ref=s9_simh_gw_p23_d1_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=037HNWHN19M1X7HS73CK&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
If so, has anybody here used this device? Are there any alternatives I should consider. I do not want to go above this £65 price point.
Many thanks for your advice .
Conor
Conor
