- Aug 10, 2019
- 2,556
- 5
- 0
I am about to buy a new Hi-Fi & home cinema system and need some advice combining them into a single system.
I have not listened to decent Hi-Fi for some 10 years now since AV took dominance. This is mainly down to me failing to put a balanced system together. I went for a Lexicon (MC-1 + amps) front end hoping I could live with digitising vinyl. I was wrong. Brilliant cinema, so-so musically.
So I need to know which Hi-Fi amps, driving the main L&R speakers, can best be integrated into an AV system. I have read through some previous threads and it seems some amps offer an "AV bypass", dedicated AV line input, or "unity/fixed gain" facility. If I understand correctly this negates the need to have the volume control set to a specific level on the stereo amp. The amp needs to be analogue friendly with a MM/MC input as I would like to start enjoying my LP12 again. This assumes that an AVR will not give the quality needed for music.
I guess I would look at a budget of around £3-5k for amp, AVR and speakers (total, not each). This will then leave me a few £k for a projector.
If anyone could suggest which amps would suit I would very much appreciate it.
Thank you.
Thank you.
