Station Scheduler
tobybeardsall
I listen to a DAB radio at work, but I often listen to different stations throughout the day. Is there a unit that allows me to set multiple timers that will automatically change station at a pre-determined time?
My only suggestion would be whether you can set alarms on the unit to the time you want and to play the station you want?
For instance, on my Sonos, an alarm is set so that it will come on at 0600 with BBC Radio 4 then at 0900 an alarm is set for Times Radio.
Just a thought!
