- Aug 10, 2019
- 2,556
- 5
- 0
I need some help.
Have recently had to dump my old hifi, and now have nothing apart from a computer and audioengine A2 speakers.
I want to have more volume and better quality though.
Therefore I want to build up a system from scratch that can do the following:
- Play the tracks stored on my mac on itunes
- Stream from online sites (prefer Spotify)
- Ideally wifi, but not essential
- Budget of about £1600 in total, but if it can be done for less than that would be a bonus.
- Good quality sound but doesn't have to be the absolute best
The options i've looked at (and i appreciate these don't all do all of the above)
- Arcam solo neo (doesn't support spotify)
- Mac to Amp (not sure which is the best way to connect)
- Mac to DAC to Amp
- the last 2 options with Apple Airport express aswell
- Mac to amp via Sonos
To be honest I'm a bit lost, and any advice would be appreciated including recommendations for amps, speakers etc. I'm planning on going to a couple of stores this afternoon to have a look at some options
Many thanks
- Mac to DAC to Amp
Many thanks
